TheSalamander
Aug 18, 2021Guide
RBK852 New Owner - so far so good (Nest, Amazon Echo/Fires, Ring, August etc) with Google Fiber
Just received my RBK852 and after updating to firmware 4.6.3.9 I've gone through the somewhat tedious task of remapping my WiFi devices that were on separate 2.4/5Ghz WiFi SSIDs to a single Mesh WiFi...
Aug 20, 2021Guru - Experienced User
Ok kewl.
Your using the C-wire so you should experinece any low battery problems then.
Enjoy.
TheSalamander
Aug 25, 2021Guide
A quick update as I know from reading the forum some people are having issues with the v4.6.3.9 firmware / RBK85x series. So far my setup continues to work fine. I have ordered an extra satellite which arrives tomorrow and will allow for more wifi coverage across the back garden. The only real oddity I have noticed is an infrequent disconnect/reconnect of a wifi device, but this has happened far less the last 24 hours once I stopped renaming/remapping/starting and stopping things but is something to keep an eye on.
I have in general kept the default settings for WiFi etc, and once I've had another week or so to confirm things are stable I may make a few tweaks.
I just tried a speed test on my Dell XPS 13 9300 running Windows 10. Connected via the 5Ghz WiFi to the satellite which has a hard wired backhaul. I received 5ms ping; 239 Mbps download; 119 Mbps upload.
Doing a similar speed test on my Intel NUC connected via ethernet I get 4ms ping; 699 Mbps download and 940 Mbps upload.
regards
Alex
- FURRYe38Aug 25, 2021Guru - Experienced User
Good to hear.
Please mark your thread as solved so others will know.
Enjoy.
