devindbest
Nov 30, 2021Aspirant
RBK852 Not reaching advertised speeds
I purchased the "Orbi Tri-band Mesh WiFi 6 System, 6Gbps, Router + 1 Satellite" back in September but ever since setting it up it hasn't reached the advertised speed, it won't even reach higher speed...
Nov 30, 2021Guru - Experienced User
What ISP speeds UP and Down do you pay for?
What wired and wireless devices are you speed testing with?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
devindbest
I have firmware version V4.6.3.16_2.0.51.
The model number for my modem provided by Centurylink is C3000Z and I'm not totally sure what else you were asking.
The ISP speeds I pay for is 140M download which I'm assuming is 140MBPS and it doesn't even tell me the upload speed that I pay for.
The wired device I am testing with is my PC and the wireless device I am testing with is my iPhone 12Pro MAX which at the time of testing the speed was right next to the Orbi Router.
The size of my home is 3,258 sqft.
The distance between the Orbi Router & the Orbi Satellite is most likely less than 30 feet or right on the dot. I have my router placed upstairs in my office room and the satellite downstairs.
- FURRYe38Nov 30, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- devindbestNov 30, 2021Aspirant
I did the option 1 you provided, however, after setting it to transparent bridged mode the Orbi wifi never worked. What could be causing that?
I would contact the ISP to see if there is any configuration information needed on the RBR when the modem is bridged. Possible missing something here. Ask them if there is user name and password needed...
Try a power OFF of the modem and RBR for 1 minute then back ON...
