devindbest
Nov 30, 2021Aspirant
RBK852 Not reaching advertised speeds
I purchased the "Orbi Tri-band Mesh WiFi 6 System, 6Gbps, Router + 1 Satellite" back in September but ever since setting it up it hasn't reached the advertised speed, it won't even reach higher speed...
Nov 30, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
devindbest
I did the option 1 you provided, however, after setting it to transparent bridged mode the Orbi wifi never worked. What could be causing that?
- FURRYe38Nov 30, 2021Guru - Experienced User
I would contact the ISP to see if there is any configuration information needed on the RBR when the modem is bridged. Possible missing something here. Ask them if there is user name and password needed...
Try a power OFF of the modem and RBR for 1 minute then back ON...
