limano
Oct 04, 2020Aspirant
RBK852 on different subnet from router (orbi 192.168.1.1 router 192.168.200.1)
When I installed the Orbi wifi it configured automatically. My main router ip gateway is 192.168.200.1 and the Orbi configured at 192.168.1.1 I turned off wifi on the main router that is connect...
- Oct 04, 2020
What is the mfr and model # of this modem? Any chance this modem can be bridged?
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option#1 if possible. Check with your ISP about this...If not you can go for option#2 or #.
Oct 04, 2020Guru - Experienced User
Your running a double NAT condition which isn't recommended. I would either remove the upstream router and use the RBR as your main host router and connect everything there, or use the up stream router and configure the RBR for AP mode so anything connected to the Orbi system will be on the same subnet...
- limanoOct 04, 2020Aspirant
Hi, thanks for the reply.
I'm not a network expert. Are there any step by step instructions from configuring the RBR for AP mode?The upstream router is actually a modem/router/wifi from my internet provider Rogers. I disabled the wifi from the modem router.- FURRYe38Oct 04, 2020Guru - Experienced User
Once you get the modem bridged, use the RBR850 as your main host or use AP mode which wold be the easiest way, you'll be fine.
Looks like you found a solution.
Enjoy. :smileywink:
limano wrote:Hi, thanks for the reply.
