limano
Oct 04, 2020Aspirant
RBK852 on different subnet from router (orbi 192.168.1.1 router 192.168.200.1)
When I installed the Orbi wifi it configured automatically. My main router ip gateway is 192.168.200.1 and the Orbi configured at 192.168.1.1 I turned off wifi on the main router that is connect...
- Oct 04, 2020
What is the mfr and model # of this modem? Any chance this modem can be bridged?
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option#1 if possible. Check with your ISP about this...If not you can go for option#2 or #.
limano
Hi, thanks for the reply.
I'm not a network expert. Are there any step by step instructions from configuring the RBR for AP mode?
The upstream router is actually a modem/router/wifi from my internet provider Rogers. I disabled the wifi from the modem router.
Oct 04, 2020Guru - Experienced User
