limano
Oct 04, 2020Aspirant
RBK852 on different subnet from router (orbi 192.168.1.1 router 192.168.200.1)
When I installed the Orbi wifi it configured automatically. My main router ip gateway is 192.168.200.1 and the Orbi configured at 192.168.1.1 I turned off wifi on the main router that is connect...
- Oct 04, 2020
What is the mfr and model # of this modem? Any chance this modem can be bridged?
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option#1 if possible. Check with your ISP about this...If not you can go for option#2 or #.
Mikey94025
Oct 04, 2020Hero
limano wrote:My question is, what is the best way to configure the network or routers so that devices connected to the main router can see and talk to devices connected to the Orbi and vice versa.
It seems the real problem here is that you should have all your devices connected to the Orbi (wired as well as wireless). Your Orbi became the router and everything should connect to it.
