NYHusker
Mar 08, 2025Tutor
RBK852 one satellite down after manual upgrade to latest firmware 7.2.7.15
Own Orbi RBK852 and added an additional RBS850. System was working fine with both satellites showing up in the app and web console and both satellites having devices connected to them. Manually upd...
CrimpOn
Mar 08, 2025Guru - Experienced User
The Orbi AX products appear to be very sensitive to the sequence of firmware updates.
Satellites done first. Router done last.
It appears that you did exactly this and the system reported all units on the same firmware.
Does the missing satellite appear on the web interface Attached Devices display as "Disconnected"?
- NYHuskerMar 08, 2025TutorI did exactly opposite of that. Updated the router first then the satellite. I'll reset and try again
I tried it the way you suggested, and the satellite was still missing, so I ended up downgrading the firmware, and everything came back up. Looks like firmware 7.2.7.15 is broken!
