KOR-CAT
Nov 03, 2019Aspirant
rbk852, Orbi Satellite Model RBS850, spec true?????
http://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf Official Netgear RBK852 PDF 140~141p RBS850 spec Radio data rates 2.4 GHz: Max 400 Mbps 5 GHz Front haul: Max 866 Mbp...
theBrick89
Nov 04, 2019Star
FURRYe38 wrote:Are you sure you read that correctly from the PDF file?
Radio data rates: Pg 139
2.4 GHz: Max 1200 Mbps
5 GHz Front haul: Max 2400 Mbps
5 GHz Back haul: Max 2400 Mbps
Pg 139 is RBR850, Pg 141 is RBS850. Both are correct on paper.
I wonder if Satellite is really that slow.
Nov 05, 2019Guru - Experienced User
I see. I'll see if I can get some confirmation on this.
- ErnestTheGreatNov 06, 2019NETGEAR Employee Retired
KOR-CAT and FURRYe38 there is a typo in the user manual the satellite specs are same as the router. NETGEAR is working on updating user manual.
Satellite specs on page 141 should also read:
- 2.4 GHz: Max 1200 Mbps
- 5 GHz Front haul: Max 2400 Mbps
- 5 GHz Back haul: Max 2400 Mbps
- FURRYe38Nov 06, 2019Guru - Experienced User
Thank you ErnestTheGreat Great to know the actual specs are the same between them. I thought they were.
:smileyvery-happy:
