houtany
Apr 26, 2021Tutor
RBK852 packet loss on Zoom / FaceTime / internet dropping
My RBK852 system is experiencing random packet loss (over 80%) when on Zoom or FaceTime on my iMac (latest model) or iPhone 12 Pro - both runing latest operating systems), and it also randomly drops ...
Apr 28, 2021Guru - Experienced User
houtany wrote:My RBK852 system is experiencing random packet loss (over 80%) when on Zoom or FaceTime on my iMac (latest model) or iPhone 12 Pro - both runing latest operating systems), and it also randomly drops internet.
The satellite is in my office which is about 30-40 feet from the router which is centrally located in my house. The house is 3,000 sq.ft. and only one story. Speedtests via the router settings is over 900mb download (router wired to modem) and around 420mb download on iPhone 12 Pro (wifi) and same on my iMac which is wired to the satellite via ethernet.
Both router and satellite are running v3.2.18.1_1.4.14 firmware. I've tried the following:
Try downgrading to v22?
- power cycling modem then RBR / RBS (in the proper order, etc.)
- Upgrading both RBR and RBS to firmware V3.2.18.1_1.4.14
- disabling SIG ALP< This should be enabled.
- disabling 2.4ghz AX< Does disabling AX on 5Ghz do anything?
- disabling 20/40mhz coexistence
- setting NAT Filtering to Open
- assigning manual IP to both iMac and iPhone via router reservation + client network settings
- changing DNS to 1.1.1.1 / 1.0.0.1 / 8.8.8.8 / 4.4.4.4 in router settings and also on the client devices< Try using ISP DNS?
- changing channels to channels with less interference using WiFi Explorer (2.4ghz on CH6 and 5ghz CH48) <Try channel 40?
- disabling daylight savings time setting for router<This should be enabled.
- updating NTP server to cloudfare's NTP
- setting CTS to 2347< Try 500?
- disabling IPv6
- disabling Traffic Meter
Generally, it works fine except when on FaceTime or Zoom call which initiallly work then lag and drop. My PS4 tends to get no more than a fair connection when playing NHL21 as well although the WiFi signal is shown to be 100% in the PS4 settings.
It seems many people are having this issue, but I was not able to find any clear solution. I would appreciate any help! I have contacted NG support as well. Thanks!
