BobGFish
Jun 22, 2024Aspirant
RBK852 poor coverage in a single room
Hello I had an RBK40 system which died. I replaced this with an RBK852 system and have the Router and Satellite in the same locations. I now struggle with poor reception in a single room for both ...
Jun 24, 2024Guru - Experienced User
Concrete and steel will be problematic for any router MESH system. It inhibits signal coverage and travel.
Something you might look at is some Power Line adapters to get the RBS ethernet connected to the back of the RBR.
BobGFish
Jun 25, 2024Aspirant
Its not a problem between RBR and RBS regardless of location in my apartment. It's an issue with client devices only in a single room which previous worked well with a much older Orbi system. If I was to purchase another RBS I'm more worried about having three devices in a very small area. I do realize I can turn Wifi Transmit power down. I just don't want to waste money on another RBS if there is some setting or config option I may have missed.
