Kielty
Aug 31, 2021Star
RBK852 query on backhaul status
I have a fibre connection to my Orbi system 300 DL 50 UL and my system is configured as such.. Router - wireless to Sat 1 which is subsequently wired to Sat 2, Sat 2 is not in wireless range of e...
- Aug 31, 2021
Sounds like the signal and status is right on the boarder of good and poor and where your debarcation is for the ethernet to the RBS2. You can possible extend the LAN cable from the newer location of RBS1 to the wall jack? Or is this one cable out to the RBS2 one long length?
There are simple LAN cable barrel connectors that would work as well to add on a longer cable section to whats in place now so you can move the RBS1 to the better location.
Kielty
Aug 31, 2021Star
about 35 ft from router to Sat 1 and then another 50ft on to sat 2 from sat 1. Is the router somehow getting confused as to wireless from Sat 2?
i will switch off sat 2 and see if the backhaul status changes and report back..
Aug 31, 2021Guru - Experienced User
- KieltyAug 31, 2021Star
thanks FURRYe38 - didn't make any difference. Must be just on the edge of the range.
As long as its not causing any issues i will leave as is!!
- FURRYe38Aug 31, 2021Guru - Experienced User
So the status with RBS2 off reports Poor or Good on the RBS1?
- KieltyAug 31, 2021StarStill reports as poor although no lights. I rebooted RBS1 whilst 2 was off. Reconnected wirelessly and blue LED. In the router management page still showed 5G poor backhaul.
