jmcvey90
Apr 07, 2020Tutor
RBK852 Roaming
I'm noticing that certain clients hang on to a weaker signal instead of handing off when the client is moved. For example, I have the router upstairs and a satellite downstairs. My laptop will be ass...
Apr 07, 2020Guru - Experienced User
It's up to devices to pick and choose which single there connected too. Even though the signal maybe low, they may hold on to that single until the devices is either rebooted or the wifi adapter is turned off for 5 seconds then back on then it would pick up the stronger signal.
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
- jmcvey90Apr 07, 2020Tutor
Hmm, I thought I had enough distance between them (especially since they're on different levels) but I'll try to space the satellite a bit further away and see how that works out.
Thanks for your help!
- FURRYe38Apr 08, 2020Guru - Experienced User
The distance can be farther than 30 feet as well. Kind of depends on your building layout.
Good Luck.
