jmcvey90
Apr 07, 2020Tutor
RBK852 Roaming
I'm noticing that certain clients hang on to a weaker signal instead of handing off when the client is moved. For example, I have the router upstairs and a satellite downstairs. My laptop will be ass...
jmcvey90
Apr 07, 2020Tutor
Hmm, I thought I had enough distance between them (especially since they're on different levels) but I'll try to space the satellite a bit further away and see how that works out.
Thanks for your help!
Apr 08, 2020Guru - Experienced User
The distance can be farther than 30 feet as well. Kind of depends on your building layout.
Good Luck.
