tinacioffi
Nov 05, 2021Aspirant
RBK852 Satellite Disappears when Wired via Ethernet
My RBK852 AX6000 Satellite does not appear in my device list once I connect it back to the Orbi Router via Ethernet. My router is set to AP Mode In order to work with my ISP's modem (that I'm told d...
Nov 05, 2021Guru - Experienced User
How are you connecting the RBS to the RBR? IT should be connected in either one of these configuration when ethernet connected:
How long are you waiting to check the RBRs web page after connecting the RBS via ethernet?
- tinacioffiNov 05, 2021Aspirant
Firmware: V4.6.3.16_2.0.51
I do have it configured as in the third illustration you showed me. It's going into a switch.
When I log in through the IP Address it says that there is a satellite connected but when I look at the device list the satellite no longer appears. If I pull the ethernet cable out and run via wifi it appears in my device list.
i waited over an hour before checking the RBR page.
- FURRYe38Nov 05, 2021Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
If you connect the RBS directly to the back of the RBR with out the switch, does the RBS appear correctly?
