tinacioffi
Nov 05, 2021Aspirant
RBK852 Satellite Disappears when Wired via Ethernet
My RBK852 AX6000 Satellite does not appear in my device list once I connect it back to the Orbi Router via Ethernet. My router is set to AP Mode In order to work with my ISP's modem (that I'm told d...
tinacioffi
Firmware: V4.6.3.16_2.0.51
I do have it configured as in the third illustration you showed me. It's going into a switch.
When I log in through the IP Address it says that there is a satellite connected but when I look at the device list the satellite no longer appears. If I pull the ethernet cable out and run via wifi it appears in my device list.
i waited over an hour before checking the RBR page.
Nov 05, 2021Guru - Experienced User
What is the Mfr and model# of the ethernet switch in the configuration?
If you connect the RBS directly to the back of the RBR with out the switch, does the RBS appear correctly?
