pickwit
Aug 29, 2020Tutor
RBK852 satellite does not allow NAT Loopback
My RBK852 satellite does not allow me to gain wifi access to my domain name of my camera DVR internally. However, I can access this domain when connecting with wifi from the router side ie. the rou...
- Sep 05, 2020
Thank you for letting us know.
Enjoy. :smileywink:
pickwit wrote:My problem has been sorted out by Duxbury and Netgear. They sent me a hot-fix firmware which resolved this issue and NAT loopback onthe satellite works flawlessy whether wired or not.
I'm sure an update will be rolled out shortly.
Thank you Duxbury and Netgear support.
Aug 29, 2020Guru - Experienced User
- pickwitAug 30, 2020Tutor
FURRYe38 wrote:What FW version are you using?
Something to ask NG support about:
https://www.netgear.com/support/#
I'm using latest firmware: V3.2.16.6_1.4.4
- pickwitSep 05, 2020Tutor
- FURRYe38Sep 05, 2020Guru - Experienced User
Enjoy. :smileywink:
