kvtong93's avatar
kvtong93
RBK852 satellite wireless backhaul
Hello Everyone, I have a question, if I add one more satellite to orbi system,how can I let two satellite do the wireless backhaul to extend the distance of my wifi system, thanks
  • anyone? I don't know if sync rbk8 series satellite with satellite is possible.
    • FURRYe38's avatar
      You can add another RBS. ALL RBS perform wired or wireless backhaul and help extend the wifi signal that comes from the RBR.
    You are not limited to one wired satellite.... on my setup I have a switch "downstream" of the RBR850....  I have two satellites (RBS5's) connected via CAT5 back to the switch.    My RBS850 is wireless back to the RBR850.
    Summary:  run additional CAT 5 or 6 to the location you want to put another satellite and it will work fine.
