Shane204
Sep 26, 2021Tutor
RBK852 Satellite
I can see detailed port statistics for the Orbi base but there are no similar stats available for the Satellite device. For example, on the base, I go to the BASIC Home page, Click the ADVANCED tab then in the Internet Port pane I click Show Statistics button .. Where is this same information for the satellite device? I can browse to the satellite and see some information but not nearly as detailed as the base device.
I have RBR850 Firmware V4.6.3.16_2.0.5.1
Thank you for any advice you can provide..
1 Reply
There isn't...
