Langley1981
Aug 13, 2020Aspirant
Rbk852 set up issue with eir
I am in need of help setting up the Orbi Mesh system. I went though a basic set up and it wouldn’t connect to the internet. I’m with eir in Ireland and their technical support was really poor. They as...
Aug 13, 2020Guru - Experienced User
Langley1981
Firmware V3.2.10.11_1.2.12
Service provider modem is Huawei ONT
Service provider is eir and I previously used their router which was FN2000 which worked fine.
- Langley1981Aug 13, 2020AspirantI should also add Eir told me to add vci and vpi settings but they are not in the admin page or appear not to be. They said they use Chap authentication and it’s multiplex llc based
- FURRYe38Aug 13, 2020Guru - Experienced User
Not sure if Orbi will support your ISP ONT directly.
Only thing to try would be to put the prior router online. Connect the RBR to this router and use the ISP routers DMZ for the RBR and see if that works.
You can try v32 FW and see if this helps any however I don't it it will:
