AJ-711
Jul 29, 2021Tutor
RBK852 Set up questions…
So I recently ordered the RBK852 & it was delivered yesterday in hopes of using it as future proof for my smart home. I already have close to 50 devices from Alexa Echos to Dyson fans to ring securit...
- Jul 29, 2021
AJ-711 wrote:I understand the placement of router & satellite but in order to achieve more than 30ft of separation & have them properly placed in the house for best coverage...Would it hurt if I connected the router to the Spectrum Cable modem with a 15ft CAT 7 cable? No. Or would this drastically impact performance?
Jul 29, 2021Guru - Experienced User
AJ-711 wrote:So I recently ordered the RBK852 & it was delivered yesterday in hopes of using it as future proof for my smart home. I already have close to 50 devices from Alexa Echos to Dyson fans to ring security & a bunch of lights & plugs...On & on.
...I've not started the set up yet as I was waiting on my ISP Spectrum to deliver my new modem today I just upgraded to their One Gig plan.
...I have an issue with planning on how to locate the router & satellite at least 30ft apart due to where my cable enters my home.
...Im new to this networking stuff but would there be any harm in me connecting the router to the cable modem with 10-15ft of CAT-7 cable so that I can achieve more than 30ft spread between router & satellite?? No, technically cable lengths could be over 100feet in length.
If not, any suggestions?
I live in small ranch style house 1400sq ft
Make sure the RBR is on main level or 2nd level. Basements are not recommended places for any wifi router. https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite📡
AJ-711
Jul 29, 2021Tutor
I understand the placement of router & satellite but in order to achieve more than 30ft of separation & have them properly placed in the house for best coverage...Would it hurt if I connected the router to the Spectrum Cable modem with a 15ft CAT 7 cable? Or would this drastically impact performance?
thank-you.
- FURRYe38Jul 29, 2021Guru - Experienced User
