Jon20175
Apr 07, 2020Aspirant
RBK852 slow WiFi
Hey y’all I have broadband service and get 50-70 mbps over an old Apple AirPort Extreme. I installed my orbi and one satellite and the WiFi speed is capped at 10mbps. I thought it maybe increase...
Jon20175
Apr 17, 2020Aspirant
Thanks for recommendation. Tried factory reset. No change. Tried unplugging satellite so only focused on base unit, no change.
Bout ready to return and find a better solution.
Apr 17, 2020Guru - Experienced User
Helpful to know the Mfr and model # if the adapter.
- Jon20175Apr 17, 2020AspirantThe orbi is the RBK852
The ISP antenna is
Mikrotik
RBSXTR
R11e-LTE-US
RouterOS v6.46.4
That is all that is connected. Not sure of any adapters.
Thanks
Jon - FURRYe38Apr 17, 2020Guru - Experienced User
You reported using "Dell is wireless." ?
- Jon20175Apr 17, 2020AspirantSorry. I was just trying to show that speeds was device agnostic. I don’t get any higher speed regardless of PC or Mac. Mobile or laptop. I am somehow capped at 10mbps. I have login to antenna and can see it coming in faster.
