Jon20175
Apr 08, 2020Aspirant
RBK852 slow WiFi
Hey y’all I have broadband service and get 50-70 mbps over an old Apple AirPort Extreme. I installed my orbi and one satellite and the WiFi speed is capped at 10mbps. I thought it maybe increase...
Jon20175
Apr 13, 2020Aspirant
So I am confused on your methodology.
I have plugged in an AirPort Extreme directly to Mikrotik. Get 40mbps+ wirelessly on all devices Mac and PC.
I plugged in laptop to Mikrotik. Get 40 mbps+.
I plug in orbi to Mikrotik. Get 10 mbps-.
The problem seems to be based in the orbi, not the model and mfg and firmware of other devices, right?
Mikey94025
Apr 18, 2020Hero
Did you use the same ethernet cable to connect the Orbi to your Mikrotik that you used for the AirPort Extreme and the laptop? It certainly does seem to be your Orbi base unit, assuming everything else is exactly the same (same cable used, connected to the same port on the Mikrotik).
- Jon20175Apr 18, 2020AspirantYes. The mike Otis is mounted high on the exterior of the house. A single cable is run to a place in the house. I have no ability to change out the cable. So the antenna end cable are the same.
Jon - FURRYe38Apr 18, 2020Guru - Experienced User
Do you have your prior router by chance? IF you do. you might do this, swap in the prior router and speed test. See if speeds are to spec. if it is, then this point to the RBR.
I presume if a factory reset has been performed and setup from scratch on the RBR, and speeds are still not to spec, I would presume the RBR is faulty. Only other way to check the RBR out is to take it to a different location with a different ISP Modem and see if the problem follows. If it doesn't, then the issue is between the RBR and your particular ISP Modem.
