Jon20175
Apr 07, 2020Aspirant
RBK852 slow WiFi
Hey y’all I have broadband service and get 50-70 mbps over an old Apple AirPort Extreme. I installed my orbi and one satellite and the WiFi speed is capped at 10mbps. I thought it maybe increase...
Jon20175
Apr 18, 2020Aspirant
Yes. The mike Otis is mounted high on the exterior of the house. A single cable is run to a place in the house. I have no ability to change out the cable. So the antenna end cable are the same.
Jon
Jon
Apr 18, 2020Guru - Experienced User
Do you have your prior router by chance? IF you do. you might do this, swap in the prior router and speed test. See if speeds are to spec. if it is, then this point to the RBR.
I presume if a factory reset has been performed and setup from scratch on the RBR, and speeds are still not to spec, I would presume the RBR is faulty. Only other way to check the RBR out is to take it to a different location with a different ISP Modem and see if the problem follows. If it doesn't, then the issue is between the RBR and your particular ISP Modem.
