Michek
Mar 22, 2020Aspirant
RBK852: Speed at 5GHz 801.22ac
Hi! What maximum speed does the Orbi RBK852 kit support at 5GHz 801.22ac? I read in an Amazon review that the maximum speed supported at 5GHz 801.22ac is 867 Mbps. Is that correct? Many than...
Mar 22, 2020Guru - Experienced User
Orbi AX6000 Router and AX6000 Satellite (2400 + 2400 + 1200Mbps)†
- MichekMar 23, 2020Aspirant
Hi FURRYe38!
Thanks for your reply!
Maybe I'm too stupid to understand this, but where can I find out how fast the system works in this environment?
Thanks!
Michek
- FURRYe38Mar 23, 2020Guru - Experienced User
A few factors, connected wifi devices like phones and pads, etc don't all have same support for max speed rates.
Have to check with Manufacturers for this information.
WiFi Sweet Spots is a good app to see connection rates with a phone or pad while connected near a RBS or RBR.
