Mallowsm
Aug 02, 2024Aspirant
Rbk852 trying to add another satellite
Currently have rbk852. Bought an additional satellite rbs850. It will not sync no matter what I do, try and sync it via the app, router login page or just sync buttons on router and satellite. Plug...
- Aug 03, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Aug 03, 2024Guru - Experienced User
What happens if you ethernet connect the RBS to the back of the RBR, with all existing RBS turn OFF?
Does the RBS appear on the RBRs web page under connected devices and does it get an IP address?
If it does, see if you can access the RBS web page and update the RBS manually to same version of FW as what is on the existing RBR and RBS.
- MallowsmAug 03, 2024AspirantThanks for your reply. So I got it to work earlier today.
I did the firmware update before posting original query and tried hardwiring it to the rbr.
In the end I turned off my original RBS. Found it in the attached devices via the router login.net interface. Removed it from the listing. Then synced up the new RBS whilst it was hardwired to the rbr. Synced successfully. Then turned my original RBS back on and it connected back just fine.
Hope this helps someone out there.- FURRYe38Aug 03, 2024Guru - Experienced User
Enjoy. 📡
