simultech2
Nov 18, 2021Aspirant
RBK852 unbearably slow
I have had an Orbi RBK852 for about 3 months in a larger house (ISP router doesn't reaching far enough), and its unbearably slow. I'm at a loss of what I can try, so looking for any ideas. Here is ...
Nov 18, 2021Guru - Experienced User
If your ISP modem has a built in router and wifi, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
