Kevin923846
Sep 22, 2021Star
RBK852 useless after latest firmware update!
Did anyone else experience a complete nightmare with the latest firmware (4.6.3.16_2.0.51) on the RBK852 / RBK853? It completely crashed my whole system. First the satellites disapeared. Then I d...
Sep 22, 2021Guru - Experienced User
Do you have a upstream router infront of the RBR?
Kevin923846
Sep 22, 2021Star
This is the same exact set up I've had for the last 6 months with my Netgear 852 without a problem and 5 years prior in the same set up. I don't know the model of the modem. It's a Genesis glass fibre model. Nothing in my system has changed EXCEPT the firmware update which has a definite issue. Many people reporting this.
- FURRYe38Sep 22, 2021Guru - Experienced User
So you mentioned that you had switched to AP mode? Did the RBR work in this mode?
No change of checking out the modem mfr and model#?
- Kevin923846Sep 22, 2021Star
Now? No, it no longer works or can even be found in AP mode.
The modem is a Genexis 7840. I have used three other routers and the NG in AP mode for years. This problem started as soon as the firmware was updated. Never a hint of an issue prior. It has to do with the "security" updates they made in the firmware. I am quite certain.
I recommend you block NGs autoupdate services on your host router then downgrade back to v3:
http.fw.updates1.netgear.com
