Anukfernando
Apr 08, 2020Aspirant
RBK852 Verizon FIOS App Streaming doesn’t work
I just installed AX6000 - RBK852 at home. I have Verizon FIOS 1GB up/down. I use the RBK852 in AP mode plugged into the FIOS quantum Router. I get excellent speeds. Running latest firmware. I got e...
Anukfernando
Apr 09, 2020Aspirant
What Firmware version is currently loaded? V3.2.10.11_1.2.12
As I mentioned, when I connect to the network via my old AP (different SSID) the Verizon FIOS APP streaming works fine. So its not the APP. When I switch to the new SSID off the RBK852 the streaming stops. So I know its the netgear AP. Is there someone else out there who has the Orbi WiFi 6 System AX6000 (RBK852) with FIOS and the FIOS TV APP on IOS to test?
Apr 09, 2020Guru - Experienced User
You might send this guy a message and see:
https://community.netgear.com/t5/Orbi-AX/Verizon-Fios-ONT-amp-AX6000/m-p/1885881#M2661
Or file a support ticket with NG:
