DBV
Dec 22, 2019Apprentice
RBK852 WiFi Speeds
Just setup our new RBK852. We did have an Orbi RBR50. We have 1gb service through Spectrum and it does reach close to 1gb hardwired. On the RBR50 with iPhone 11 Pro speeds were usually around...
Dec 22, 2019Guru - Experienced User
Use WiFi Sweet Spots on your iPhone to see what the connection rate is between the iphone and RBR...
- DBVDec 22, 2019Apprentice
Wi-Fi Sweetspots shows connection from 672 to 693. Is that what you need? Thanks!
- DBVDec 24, 2019Apprentice
Anyone else have anything to add about my speeds? Appreciat the help. :)
- BanditoDec 24, 2019Luminary
Your speeds sound perfectly normal to me. Getting a full 1 Gps connection over WiFi 6 would require you to be probably within a foot or two of the router and having all other conditions be perfect in the room. The full advertised speeds are rarely, if ever, achieveable in the real world.
Out of curiosity, how close are you to the router when you test your speeds?
