ichan7's avatar
ichan7
Initiate
Aug 12, 2021
RBK852 won't let me login after updating firmware to 4.6.3.9
Hi all,     Is there anyone encountering problems with login after updating RBK850 series routers and satellites to firmware 4.6.3.9? I have just updated mine and are not able to login through web ...
  • ichan7's avatar
    ichan7
    Aug 13, 2021
    Hi FURRYe38, The problem has been sorted. Firstly, the satellite device connected to the router automatically when I powered it on after its being off for 1.5 hours. Web remote management worked when I attempted connecting it over HTTPS. However, I no longer see the remote management options which could have been removed by the firmware update. Anyway, I am now able to manage my Orbi system with a web browser. Thank you for the advice and looking into it. Cheers, Isaac
