Shaggylady_40
Jun 20, 2021Aspirant
RBK852
Hello I cannot connect any of my devices that are 2.4GHZ. I tried the troubleshooting to uncheck the 5G box. Not working I just keep getting reputed to change my password. I have two networks now ATT ...
LadySapphy
Jun 20, 2021Guide
Have you tried turning off AX mode?
- Shaggylady_40Jun 20, 2021AspirantHow do I do that?
- FURRYe38Jun 20, 2021Guru - Experienced User
Remove the check mark and select Apply.
- Shaggylady_40Jun 20, 2021AspirantI want both 2.4 and 5. If I uncheck 2.4 will that allow the 2.4 devices ti be added to the network?
- LadySapphyJun 20, 2021Guide
Log into the interface via the web, go to advanced then go to setup then go to wireless setup. In there you will see AX mode on and off.
