vivek283
Nov 10, 2019Guide
RBK852/Orbi Wifi6 Slow backhaul
Got the new RBK852/Orbi Wifi 6 system today from BB. Getting it up and running was easy. Started testing speeds and realized that the speed between the satellite and the router is very low. The satel...
NateIU
Nov 11, 2019Tutor
Ignore my previous post. I was actually able to resolve this and am seeing good speeds now.
Can't seem to find a way to delete or edit posts here.
Bandito
Nov 11, 2019Luminary
- NateIUNov 11, 2019Tutor
I wish it were something of note related to Orbi AX settings, but it was stupid: It was a bad ethernet cable to the machine connected to the Satellite. It was registering properly as gigabit full-duplex, and upstream to the machine was fine, but downstream must have been error correcting. Because it was working otherwise, I unfortunately blamed the Orbi until I could do more testing.
Replaced the cable and things sped right back up again. With my laptop wired to the Orbi, I can now get close to Gigabit transfer speeds. Wireless AC (MBP isn't AX yet), I get around 500-600Mbit now across the Orbi backhaul (Router to Satellite) to the server, which isn't bad all things considered...
My Orbis are also 2 floors apart through floors with radiant heating, so it's pretty impressive.
This is with the 3.1.6 firmware (which was posted live briefly but is now apparently beta?).
- FURRYe38Nov 13, 2019Guru - Experienced User
There is newer FW available should you be interested:
NateIU wrote:I wish it were something of note related to Orbi AX settings, but it was stupid: It was a bad ethernet cable to the machine connected to the Satellite. It was registering properly as gigabit full-duplex, and upstream to the machine was fine, but downstream must have been error correcting. Because it was working otherwise, I unfortunately blamed the Orbi until I could do more testing.
