vivek283
Nov 10, 2019Guide
RBK852/Orbi Wifi6 Slow backhaul
Got the new RBK852/Orbi Wifi 6 system today from BB. Getting it up and running was easy. Started testing speeds and realized that the speed between the satellite and the router is very low. The satel...
NateIU
Nov 11, 2019Tutor
I see this as well, internally on the network between Router and Satellite. When connected to the Satellite via WiFi, I can pull a solid 350Mbit/sec externally, so the Backhaul seems fine.
But when transferring within my network, I get very slow speeds for some reason between devices connected to my Router and Satellite. Uploading to a Synology box (1000mbit wired to Satellite) from a MacBook Pro (1300 tx to Router), I'm seeing like absurd 50Mbit speeds.
Hopefully it's just a firmware problem they can fix...
Nov 12, 2019Guru - Experienced User
How are the speeds with you connect your NAS to the RBR?
NateIU wrote:I see this as well, internally on the network between Router and Satellite. When connected to the Satellite via WiFi, I can pull a solid 350Mbit/sec externally, so the Backhaul seems fine.
