spacecase-nld
Oct 04, 2020Aspirant
RBK853 — Orbi WiFi 6 System AX6000 - static ip
I would like to asign a static IP address to my RBK853 — Orbi WiFi 6 System AX6000 While logg-in to to router I selected Advanced->LAN Setup, and named the desired Device and selected IP addre...
Mikey94025
Oct 04, 2020Hero
What IP did the NAS device have assigned to it before you edited it? Are you only changing the last number?
Also, what device name string are you entering? Does it work if you try a name without any special characters (i.e., only use letters and spaces)?
