spacecase-nld
Oct 04, 2020Aspirant
RBK853 — Orbi WiFi 6 System AX6000 - static ip
I would like to asign a static IP address to my RBK853 — Orbi WiFi 6 System AX6000 While logg-in to to router I selected Advanced->LAN Setup, and named the desired Device and selected IP addre...
CrimpOn
Oct 04, 2020Guru - Experienced User
spacecase-nld wrote:I would like to asign a static IP address to my RBK853 — Orbi WiFi 6 System AX6000
While logg-in to to router I selected Advanced->LAN Setup, and named the desired Device and selected IP address I want to use.
Why is that?
Why can I not a sign an Static IP to a Device. Perhaps there is a good reason for it, but I need an IP for my NAS.
Could you please clarify which device you want to have a static IP?
If you are logged into the administrative web interface on the RBR850 router and want the router itself to have a static IP address, that is done on the Orbi web interface Home Page, Internet Menu where you select "Use Static IP address" rather than "Get Dynamically from ISP". A person might do this, for example, when he has purchased a static IP from the ISP.
Sorry if I misunderstood the problem.
