spacecase-nld
Oct 04, 2020Aspirant
RBK853 — Orbi WiFi 6 System AX6000 - static ip
I would like to asign a static IP address to my RBK853 — Orbi WiFi 6 System AX6000 While logg-in to to router I selected Advanced->LAN Setup, and named the desired Device and selected IP addre...
spacecase-nld
Oct 07, 2020Aspirant
Thanks for your replies,
Not sure what happened and which change did the trick. Yesterday evening I retried and was able to create a reservered IP address for the Asustor NAS. Still giving the error, though after rebooting de Orbi. It was assigned to the expected IP adresss.
Problem solved,
Oct 07, 2020Guru - Experienced User
Usually a reboot of the router and NAS is needed to ensure the IP address change took place.
Glad it's working now. Please mark your thread and solved so others will know.
Enjoy. :smileywink:
- spacecase-nldOct 07, 2020Aspirant
Agree, but why the error message, anyway it works!
- FURRYe38Oct 07, 2020Guru - Experienced User
Possible the RBR was in a bad state or there was a bad browser cache problem.
Glad it's working. Mark your thread as solved.
Enjoy.
