migsta
Mar 02, 2020Apprentice
RBK853 - How many additional satellites?
I have an RBK853 with two satellites setup and working ok. I say OK because the iOS app is unstable at times and Orbi itself loses internet connection and satellites dop - most noticable overnight w...
Mar 02, 2020Guru - Experienced User
I have 5000sq ft home and just 1 RBS seems to cover the entire place well. Yes I have the 2nd RBS now.
Not sure how many officially NG will support. I know with Orbi AC they go far as 3-4 and thats it. However others have posted having 6 RBS to 1 RBR. No idea if that will be the same for Orbi AX.
Any Orbi RBS50 series are still not compatible wirelessly at this time. No information as of yet from NG on when this will happen nor will we see any information in this regard. I presume when they are ready and get them talking to each other over WiFi, they will announced it in the release notes and maybe make an announcment here in the forums. Until then, keep your eyes on the release notes as FW updates get posted.
- migstaMar 02, 2020Apprentice
It's primarily to try and get more signal to the outside of my home. The Orbi AX is really bad the moment I walk out of my home. It completely dies all around my home and I need strong signals around the house for outdoor cameras. I know bout the prior Orbi as I had 4 satellites plus the outdoor RBS50Y all connected and working. I sold that system, save the RBS50Y, and need to know specifically about the Orbi AX if anybody has had success with 3 or more RBS850 satellites (don't care about hard wiring RBS50 satellites - just wireless RBS850 ones). I would also like to know if the RBS50Y will work with the RBR50?
This Orbi AX is pathetic to penetrate outside my home. Inside with 2 satellites no problem - just outside.
Thanks for the response.
- FURRYe38Mar 02, 2020Guru - Experienced User
The RBSY does work wirelessly with the 50 series Orbi.
Hopefully someone may post about having 3 RBS850s. I presume 3-4 may work just fine. Placement and distance from RBR will be key as well.
- migstaMar 02, 2020ApprenticeSorry, meant if RBS50Y works with RBR850?
