vfromdc
May 23, 2020Guide
RBK853 - Only about 8 Entries in the Router Logs
My log in the router only shows about 8 last entries. How do I get see more entries there? Also I coudn't get Email working because gmail rejects it from logging into my email accont. Any ideas how ...
vfromdc
Jun 17, 2020Guide
Nothing changed for me, I still have 7 entries as before.
Chuck_M
Jun 18, 2020Mentor
My RBR850 only has about 7 log entries in the system. All options are checked on the left side. In Router mode, works fine but the logging cape seems to be broken.
- KMDonlonJun 18, 2020VirtuosoChuck_M, just got home from work, log is full however it cuts off several hours after I left this morning starting about 3 hours later logging entries. Now there seems to be some sort of total entries or some time constraints... Will have to count total entries tomorrow to see.... annoying "bug" for sure
- Chuck_MJun 19, 2020Mentor
I will go back and do the same and report.
- KMDonlonJun 20, 2020Virtuoso2 days in a row of exactly 34 entries when I get home from work. Cleared it 12 hours prior each morning before checking it when I get home. Odd part is it seems to skip logging for a few hours early on so I am not sure if it removing early entries once it hits 34??
I only have the Router Operations tick box checked FYI - KMDonlonJun 22, 2020VirtuosoVery odd, today (06-22-20) my logs only show 7 entries again when I got home from work this evening. This is bizzare
- Chuck_MJun 23, 2020Mentor
Mine too.. only about 7 entries that never seem to change and are useless.
- Blanca_OJul 06, 2020NETGEAR Employee Retired
Hi, All,
This has been brought up already to our product teams. We will provide update once new information will be available.
Blanca
Community Team - KMDonlonJul 25, 2020VirtuosoFor the past 3 days now my logs are back to "unlimited" entries. I have done nothing on my end so I don't understand what is causing this. Is there a cloud service tied into the logs?
- FURRYe38Jul 25, 2020Guru - Experienced User
Anything is possible when it comes to Orbi. Remember the one FW update fiasco back in March? That was tied to some cloud services on there side.
- vfromdcJul 25, 2020Guide
There is no change in the log entries for me, still 7.
- vfromdcAug 13, 2020Guide
There is a newer firmware available as a Hot fix which I cannot update to, automatically. I am new to Netgear, not sure I understand the difference between a regular firmware update and a hot fix. Also do I need to update to this version? Not sure whether it will have any effect on number of log entries that I am still having issues with. Thank you.
- Chuck_MAug 13, 2020Mentor
I am at version V3.2.15.32_1.3.25 on RBR850 and only have 7 or so log entries.
I dont think this issue has been fixed yet.
- KMDonlonAug 13, 2020VirtuosoIt 100% has NOT been fixed yet....
- vfromdcAug 23, 2020Guide
After updating to V3.2.16.6, my log entries have gone up from 7 to 27. The information in the logs still the same, sowing connection time, MAC address and IP address.
- vfromdcAug 31, 2020Guide
I have not made any changes, but I noticed that number of log entries went down from 27 to just 1, which is the logging into the router:
[DHCP IP: (192.168.1.7)] to MAC address XX:XX:XX:XX:XX:XX, Monday, Aug 31,2020 17:54:31
Still Firmware Version V3.2.16.6_1.4.4. This is totally useless.
I also had a hardware issue with one of the 3 units, the reset button did not work because the body was lose and had moved. I called NETGEAR support (well within the 90 days), they said to ship the unit at my expense and then they will send the replacement after they receive it. Never had that kind of experience with any company I have worked with, especially for a router that costs $1,000. I decided to keep the defective unit.
This is my first Netgear device ever and will definitely be the last one.
- FURRYe38Aug 31, 2020Guru - Experienced User
You should have asked about a cross shippment RMA. You'll need to contact a forum moderator to help you out with any RMA processes. Thats something that can't be handled here in the forum.
vfromdc wrote:I have not made any changes, but I noticed that number of log entries went down from 27 to just 1, which is the logging into the router:
- KMDonlonJan 23, 2021VirtuosoThis is still an ongoing issue, my logs are not complete and this problem has been there through the last several firmwares. Still present in V3.2.17.12_1.4.14.
- antJun 03, 2021Prodigy
Same here in my updated RBK753S-100NAS. Please fix it, Netgear! :(
Firmware Version
V3.2.18.1_1.4.14Doesn't Netgear already know this as a known issue?
FURRYe38 wrote:
What FW version are you using?
Please file a support ticket regarding this and let them know about what your seeing.
ant wrote:Same here in my updated RBK753S-100NAS. Please fix it, Netgear! :(
- FURRYe38Jun 03, 2021Guru - Experienced User
We don't know if NG is aware of this or not. I presume maybe some maybe in this thread may have already contacted them. We don't get information on whats been submitted so we have zero way of knowing. Best if users contact NG support. The more users contact them, probably more apt to get it fixed for those seeing this issue.
- Chuck_MJun 03, 2021Mentor
FURRYe38 wrote:We don't know if NG is aware of this or not. I presume maybe some maybe in this thread may have already contacted them. We don't get information on whats been submitted so we have zero way of knowing. Best if users contact NG support. The more users contact them, probably more apt to get it fixed for those seeing this issue.
Blanca_O has been specifically put on this thread since nearly it's inception.
Scroll up and you will see what I am talking about.
She has never weighed in nor commented.
Seems like Ops Normal for Netgear these days!
You would figure that only one user would have to point out a deficency for them to take it serious
Why I always ask users to make contact with NG support and open a support ticket.
