mikepade
Nov 14, 2021Tutor
RBK853 - Satellites drop Internet connection
Hi all, we have a RBK853 package and since initial installation we have the problem that the Internet connection is dropped multiple times during the day from all 2 satellites. Totally annoying w...
- Nov 14, 2021
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a full power OFF of the RBR and RBS been perfomed since last FW update?
Try disabling AX mode on the RBR for 2.4Ghz...
Nov 14, 2021Guru - Experienced User
mikepade
Nov 14, 2021Tutor
Hi there,
thank you for your quick reply.
Firmware is V4.6.3.16_2.0.51
The modem is a Telstra Smart modem, we previously had an Orbi RBR50 plus 2 Satellites RBS50 working fine on the same setup.
Home is a 2 story 300 sm single dwelling.
When connected both Satellites show blue colour indicating they successfully synced and the connection between the router and satellite is good.
Currently using channel 5 (2.4 GH) and 36 (5 GH).
2 Wifi neighbours at least 15 m away.
Yes full power off and hard reset has been performed multiple times.
ok will now try disabling AX mode for 2.4 GH.
- FURRYe38Nov 15, 2021Guru - Experienced User
Is there a model # for the Telstra Smart modem?
- mikepadeNov 16, 2021Tutor
Sorry dont have a model number for the Telstra Smart Modem.
Seems like disabling AX mode for 2.4 GH has been a positive impact so far and drop outs have reduced considerably.
Our Internet comes into the house in kind of the middle of the ground floor. We tried putting one Satellite in the far corner room of the house (more than 10 m away) but it always showed poor backhaul status in the Orbi Web interface even though the LED light was blue upon connection to the RBR850. Now it's maybe 5 m away but two walls inbetween, backhaul status is now showing as good. The other Satellite is upstairs more than 10m away also showing backhaul status as good. Once we have solved the drop outs I will try and put the Satellite downstairs back into the far room.
- FURRYe38Nov 17, 2021Guru - Experienced User
