big44
Oct 22, 2021Aspirant
RBK853 - Slow Wired Gigabit Connection
I just upgraded to Ultrafast with BT (900mb speeds). When connected directly with ethernet to the provided ISP router, I'm getting instant 900mb speeds. The speed tests literally /instantaneously/ ...
Oct 23, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Is Armor or SPC enabled on the RBR?
What mode is the modem working in currently?
The IS supports PPPoE?
When you had the modem in router mode, did you use the modems DMZ for the RBR in router mode as well and turn OFF all wifi radios on the modem?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- big44Oct 23, 2021Aspirant
Hi FURRYe38,
Current firmware is V4.6.3.16
My ISP Router I believe is the Smart Hub 2, from BT.
Yes, I've reset everything for over 5 mins and repowered.
The modem is currently in AP mode, but I've tried Router also.
PPPoE is possible, and I activated it as mentioned in original post but this did not improve anything.
I'm not familiar with 'DBZ' and 'RBR' but I did turn off all the radios on the modem.
"1. Configure the modem for transparent bridge or modem only mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly." - So I found out this isn't possible for the specific router I'm using. I thought turning off the radios bypasses the wifi.
"2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode." - I want to try this, but I'm going to need some extra details as I'm unsure how to do this.
"3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router." - I just tried this and it has given me the best results, yet not perfect. I'm currently getting about 550 download speed while right infront of the router, up from 400 originally.Thanks!
