Alextkexichi
Jul 13, 2021Aspirant
RBK853 - unable to assign IP addresses
Hello and thanks in advance for your help - let me know if there's somewhere else more appropriate to ask this question please. When I attempt to assign IP addresses to devices on my network (Adv...
- Jul 13, 2021
Seems like the values your entering and saving is good up to the point where you select the Apply button and then you get the error.
I would try a factory reset and setup from scratch.
Clear out all browser caches prior to setup and walking the wizard...
Alextkexichi wrote:Hey Furry, I first attempted using Edge and then Firefox, the later both before and after clearing cache and in private mode.
What's interesting is in all scenarios, the assigned IPs all appear in the Address Reservation table so it's saving the work, but for some reason the settings are not getting applied and IPs are not getting shuffled
I have not performed a factory reset at this time - hoping that's a last resort.
Jul 13, 2021Guru - Experienced User
What browser are you using?
Be sure to clear out all browser caches before entering into the RBRs web page.
- AlextkexichiJul 13, 2021Aspirant
- tak1313Jul 13, 2021Luminary
From my experience when I used the Orbi as router, it gets assigned when the client renews the lease (or you reboot the client or router).
- FURRYe38Jul 13, 2021Guru - Experienced User
- AlextkexichiJul 14, 2021Aspirant
Factory reset did the trick - ended up being not as painful as I thought and got everything online and IPs assigned as directed. Thanks so much for your support!
