Dombekgt
Aug 29, 2022Aspirant
RBK853 - won’t connect to network but connects to guest
I have the RBK853, replaced an Airport system. Used the same network name but different password. My daughter brought her Chromebook home for the first time this year, new machine and never been in o...
Aug 29, 2022Guru - Experienced User
Are you using any special character in the ssid/password?
If so, remove them.
also, have you tried disabling AX? Could be the chromebook having issues with AX.
