BarneyH
Jun 15, 2020Follower
RBK853 & RBS50Y - when is compatibility coming?
Am I right in thinking that the RBK853 and outdoor RBS50Y are still incompatible with each other? I can't get my RBS50Y to join in Orbi mode. I then thought I could at least ask the RBS50Y to ext...
zinca
Jun 25, 2020Guide
How did you get the outdoor satellite to load that firmware? Every time I try it says the firmware is not compatible. I downloaded the zip file from Netgear, extracted the file, and attempted to install. This process worked fine to install the Pro Firmware, revert to the Orbi normal firmware, but rejected both the older and newer releases of the Extender firmware. I tried this both before and after factory resets, no success. RBS50Y unit working fine as satellite using both Orbi and Pro Firmware but won't switch to Extender. I see there are V1 and V2 models of the RBS50Y, can the V1 accept this firmware? Is there some other trick to it? Some way to check the firmware file?
Jun 25, 2020Guru - Experienced User
What broswser are you using? Try IE11 or Firefox?
What Orbi version of FW is currently loaded on the RBSY?
zinca wrote:How did you get the outdoor satellite to load that firmware? Every time I try it says the firmware is not compatible. I downloaded the zip file from Netgear, extracted the file, and attempted to install. This process worked fine to install the Pro Firmware, revert to the Orbi normal firmware, but rejected both the older and newer releases of the Extender firmware. I tried this both before and after factory resets, no success. RBS50Y unit working fine as satellite using both Orbi and Pro Firmware but won't switch to Extender. I see there are V1 and V2 models of the RBS50Y, can the V1 accept this firmware? Is there some other trick to it? Some way to check the firmware file?
