darkinners
Aug 22, 2020Tutor
RBK853 3.2.16.6 firmware delete wifi password
Since I updated my RBK853 firmware to 3.2.16.6 If I change ANY setting via webbrowser. Orbi wifi will became "insecure" meaning you can connect to my Wifi SSID without password. To remedy this i...
Aug 22, 2020Guru - Experienced User
What browser are you using? Try Edge, IE11 or Opera or Safari. Ive not had any problems with v6 FW.
How was the FW updated, thru the orbi app or RBRs web page or did you manually download the FW files and apply them? I prefer to manually download FW files and apply them directly to the RBS then RBR. Then factory reset. Press the reset button for 15 seconds then release. Walk thru the setup wizard with a wired PC and web browser.
darkinners
Aug 22, 2020Tutor
I used Chrome(PC/MAC), Edge(PC), Safari(MAC) with all extension disabled including adblocks, also cleared cookies, cache..etc
Result is all the same.
I use manual update, the firmware directly downloaded from Netgear support page.
I update the satellites first then update the router, as advise by support page.
I can only manually update the firmware as my RBK853 are in AP mode. They cannot check for new firmware themselves.
