jafox14
Feb 10, 2022Aspirant
RBK853 Alternative to OrbiLogin.com
For anyone having trouble accessing their Orbi Router user interface using the ORBILOGIN.COM, here is a solution. Use ROUTERLOGIN.NET instead. I was in a "do-loop" trying to use ORBILOGIN...
Feb 10, 2022Guru - Experienced User
What broswser are you using?
Does 192.168.1.1 work?
- jafox14Feb 10, 2022Aspirant
1.) Orbi Router Firmware is V4.6.3.16_2.0.51.
2.). Spectrum provided the Modem. Why is model number and mfr of interest?
3.). Glad 192.168.1.1 works for others. It did not work for me. Put me into the password "do-loop" on all the previously mentioned browsers.
4.). Using Mac Safari to successfully access as previously described.
Cheers!
- FURRYe38Feb 11, 2022Guru - Experienced User
To check for a double NAT condition which is not recommended.
Try using FireFox or Opera for Mac and let us know if same thing still happens when trying to access orbilogin.net or 192.168.1.1.
If it does, I recommend you review this:
Cheers!
- jafox14Feb 11, 2022Aspirant
Thank you for the info.
The Spectrum modem is a voice modem, no wifi capability.
This morning, ORBILOGIN.COM and 192.168.1.1 are now working properly on my Mac via Safari, and on my iPad via Safari. No "do loop" password reset. I checked again late last night and ORBILOGIN.COM and 192.168.1.1 were not working properly, i.e. continued to put me in the password reset do loop. Since last night, I have not reset nor rebooted any devices, nor changed any passwords, nor manually cleared any caches, and I am still running the same FW as posted previoiusly.
If all three (ORBILOGIN.COM, ROUTERLOGIN.NET, and 192.168.1.1) all point to the same location, they should all work the same way...right? But, yesterday, it didn't matter if I was using Safari, Firefox, or Chrome...the only thing that worked correctly was ROUTERLOGIN.NET.
Thanks for all the great responses. Great forum with lots of useful information.
