jafox14
Feb 10, 2022Aspirant
RBK853 Alternative to OrbiLogin.com
For anyone having trouble accessing their Orbi Router user interface using the ORBILOGIN.COM, here is a solution. Use ROUTERLOGIN.NET instead. I was in a "do-loop" trying to use ORBILOGIN...
jafox14
Feb 11, 2022Aspirant
1.) Orbi Router Firmware is V4.6.3.16_2.0.51.
2.). Spectrum provided the Modem. Why is model number and mfr of interest?
3.). Glad 192.168.1.1 works for others. It did not work for me. Put me into the password "do-loop" on all the previously mentioned browsers.
4.). Using Mac Safari to successfully access as previously described.
Cheers!
Feb 11, 2022Guru - Experienced User
To check for a double NAT condition which is not recommended.
Try using FireFox or Opera for Mac and let us know if same thing still happens when trying to access orbilogin.net or 192.168.1.1.
If it does, I recommend you review this:
Cheers!
