MeshWifi0656
Jul 11, 2023Aspirant
RBK853 AP + nodes vs WAP
Would using my RBK853 system as an Access Point with a few nodes, instead of a router, just be a more expensive set-up than having a few WAP (Ubiquiti) throughout my office area? I am struggling to u...
MeshWifi0656
Thank you for the reply. I guess my comparison was is there any real advantage to having an OrbiRBK in AP mode vs any WAP? Even consider the Netgear AX3000 Dual-Band PoE Multi-Gig Insight Managed Wifi 6 Access Point as an example. I guess the Orbi satellites would have a larger coverage area, but you are also paying a premium for other unused components of the Orbi, especially if you use a wired backhaul to each satellite.
Jul 12, 2023Guru - Experienced User
If you have a really office and office networking configuration, looking into small business or business class WAP would be recommended as the Orbi AX systems here are home class products, thus may not be ideal for an office or business setting or configuration. NG does have Orbi Pro line that is specifically more idea for the office or business environment.
