NortieNeil
May 14, 2020Aspirant
RBK853 AX6000 - Can I use an RBS 50 satellite to extend this network?
Hi folks, I have a hunch I know the answer, but I'll give it a go. I already have an RBR50 and two RBS50 satellites which work well, but I've decided to upgrade to the RBK853, which arrives tomo...
- May 14, 2020
Yes.
May 14, 2020Guru - Experienced User
No at the moment. No idea if or when NG will make prior 50 series compatible wirelessly. You can connect them wired ethernet however.
NortieNeil
Well, that's doable.
Will it be seen as the same SSID and handover to the other devices in the mesh if connected by ethernet?
- FURRYe38May 14, 2020Guru - Experienced User
Yes.
