NortieNeil
May 14, 2020Aspirant
RBK853 AX6000 - Can I use an RBS 50 satellite to extend this network?
Hi folks, I have a hunch I know the answer, but I'll give it a go. I already have an RBR50 and two RBS50 satellites which work well, but I've decided to upgrade to the RBK853, which arrives tomo...
- May 14, 2020
Yes.
NortieNeil
Well, that's doable.
Will it be seen as the same SSID and handover to the other devices in the mesh if connected by ethernet?
May 14, 2020Guru - Experienced User
Yes.
