pmoses
Apr 20, 2020Tutor
RBK853 connected devices incorrect
I have installed a new RBK853 mesh network. I installed the latest firmware. I can see the connected devices is just 13 when the actual number is 40+. Refresh or reboot does not fix the issue. Some o...
- Apr 22, 2020
I just did a factory reset (I had not done a factory reset after the firmware update.) and the connected devices seem to be showing up correctly now.
Hope I dont have to do a factory reset after every firmware update!
Mikey94025
Apr 20, 2020Hero
I wouldn't focus too much on the connected devices list, especially if you have devices with static IPs (does the list even work with static IPs?). If you really want the devices list to be accurate, consider giving everything dynamic IPs and add to your address reservation list to keep the IPs from changing.
